MXM363N pull-out keyboard lights flashing
+ More Options
Posts
  • bilyahn
    • Dec 2006
    • 1470
    Have a unit that just started doing this. Keyboard was working fine for the past 2 years, unit has 38K.
    When you pull out the keyboard all 3 green lights flash on and off in a regular pattern. Momentarily on then about 1 second off then repeat. Have replaced the following components:
    keyboard assembly
    usb conv pwb
    mother pwb
    Only thing I could find so far as a reference is this post http://www.copytechnet.com/forums/sh...esponding.html There is nothing on Sharp IDNC that I could find. Parts are known good not new.
    Before I go to the trouble of replacing the MFP PWB was hoping someone has had this issue and I'm just overlooking something simple.
    Thank you in advance for your time and effort in this matter.
    Bil
  • igi
    • 1507
    Re: MXM363N pull-out keyboard lights flashing
    maybe someone else did?
    If the DIP switch control is configured for the rear USB port only, the external keyboard unit will not function
    • faxman28
      • 436
      keyboard assembly
      usb conv pwb
      mother pwb
      Bil
      check the mother board , on some of the color machines had to replace the mother board and/or the usb hub on the mother board.
      just looked at wiring diagram for this series there is a usb hub pwb attached to mother board at cn17
      • bilyahn
        • Dec 2006
        • 1470
        Thank you for the quick replies igi and faxman. I will check those out.
        Bil
        • serviceman
          • Jun 2009
          • 71
          Bil- Any update on this? I have a 503 doing the exact same thing.
          • faxman28
            • 436
            i have done 2 503 series and a 2600 series in the past 2 months and they have all been the usb conv pwb under the pull out keyboard.
            • serviceman
              • Jun 2009
              • 71
              Ok, thanks! Ill give it a try.
              • bilyahn
                • Dec 2006
                • 1470
                faxman is exactly correct. I replaced the entire keyboard assembly AGAIN and the unit worked just fine. We took it to the shop and replaced the PWB on the keyboatd and it started working. I guess the "known" good keyboard assembly I originally used wasn't so good after all.
                Bil
