Problem traces sharp mx 2610
  • SAVCOPIEUR
    [CQ] Problem traces sharp mx 2610
    Hello,
    Sorry for my english, i'm french.... :-(
    I changed the transfer belt, the belt transfer blade and black drum kit.
    Here are the traces that I meet at present.
    Thank you in advance for your help.08.07.14.pdf
  • igi
    • 1507
    Re: Problem traces sharp mx 2610
    hi make single color copy
    and see which colors give you the problem
    start from there
    • bilyahn
      • Dec 2006
      • 1467
      Your color calibration looks way out of spec. I would recommend you clean each of the drum units and then do a color calibration and see what your test print looks like. What are the meter readings on your color drums?
      Good luck.
      Bil
      • ruben
        The New Guy
        • Oct 2012
        • 1204
        You can sometimes see this kind of effect with a stuck cleaning web.
        • SAVCOPIEUR
          Thank you all for your response.
          I cleaned all the pressure roller in the fuser unit. for the moment it works well.
          thank you
