Check for amount of memory installed on a MX-M503N
  • CES_Imaging
    • Nov 2012
    • 65
    Our repro department is looking to decrease the processing times on a few MX-M503N machines. I see that there is a 1 GB RAM upgrade available for that machine. Is there a simulation or something of the like that would allow me to see if this is installed or not? Or to check how much memory is actually installed?
    Thanks.
  • ZOOTECH
    Senior member of CRS
    • 3375
    Re: Check for amount of memory installed on a MX-M503N
    Thanks.
    TC 22-10
    • CES_Imaging
      • Nov 2012
      • 65
      Thank you! Do you happen to know what the standard amount of SDRAM is? I have 1 GB on each machine, which would lead me to believe that the memory upgrade is not installed on any of them.
      • ZOOTECH
        • 3375
        You can add 1GB for a max of 2GB; if there is an empty DIMM slot you have the standard memory, and a 1GB can be added.
        • Akitu
          Legendary Frost Spec Tech
          • Oct 2010
          • 2595
          Thanks.
          What kind of jobs are they printing that they need it ripped faster than 5 seconds? Yikes!
          • CES_Imaging
            • Nov 2012
            • 65
            Spec books for architectural firms and construction companies mostly. I'm not really sure it's necessary, they just asked me to look into it on here.
            • Akitu
              • Oct 2010
              • 2595
              I do hope they're not under the impression that more memory = faster printing. Otherwise; I do hope you're charging them for every penny of time and material that's going into it
                • 23010
                Righto. Big files means slow printing. Memory won't help that. =^..^=
