Sharp MX2600 C4-00
  • mabro1974
    • Feb 2013
    • 39
    [Error Code] Sharp MX2600 C4-00
    Hi can anyone help,
    I keep getting a re-occuring C4-00 error, it has had 2 new ptc's fitted ( in case one was fauty ) , new transfer belt and the rollers inside transfer unit cleaned ,all drum units and devs units checked to make sure not too tight and a new secondary transfer pwb ( as this is what controls the ptc voltage )
    I am now runing out of ideas for this and am only left with the pcu pwb ( which i have never known for this error )
    Any advice greatly appreciated.
    cheers
  • Akitu
    Legendary Frost Spec Tech
    • Oct 2010
    • 2595
    Re: Sharp MX2600 C4-00
    The PTCs were updated a while back to give less C4-00 faults. Are you using the updated units or the old ones?
    • MHeon71
      • 489
      3 bulletins worth checking out.
      TT-20343
      MFP-TB-450
      MFP-TB-349
      • mabro1974
        • Feb 2013
        • 39
        TT-20343
        MFP-TB-450
        MFP-TB-349
        Tried all these but still the same and i am using the updated PTC's
        • foudl
          • Mar 2010
          • 138
          Originally posted by mabro1974
          Hi can anyone help,
          cheers
          It is a long shot but it happen to me once, i purchased a board (2nd transfer)from sharp (which came from hytec) and it turned out that the board was not good .
          So maybe you should get another one to make sure ,i know it's boring but it's worth the try
