After several of these codes appearing on the Frontier SC machine, I noticed the spring (red) that applies tension to the CCD drive belt does not have enough tension on it, causing L3-00 codes. A simple washer (green) under the anchor screw shown in the picture above will alleviate this code permanently. With the SC model, the optic cavity can be accessed from the top, unlike the previous 401 machines.
