AR-168S strange problem
  • kirkeb
    • Dec 2012
    • 31
    [Misc] AR-168S strange problem
    Keyboard will not work. Or almost won't work. Numeric keys, menu, enter, exposure, magnification, mode switch won't work. Print button only works if you press and press and press, then only works if you hit the magic spot. Every time you press a key the display gets cloudy.
    However if you press #*C* to put in test command mode those work fine. Once in test command mode, the numeric keys work flawlessly. As does the print switch. The lightest touch activates it. Hit the CA key to get out of test command mode and the keys won't work again. At first I was thinking keyboard PWB. Then after discovering that they worked in test command mode....
    Any ideas?
  • ZOOTECH
    Senior member of CRS
    • 3375
    Re: AR-168S strange problem
    Any ideas?
    The key switches may work under the diag conditions, but the control for regular operations may not enable the switches.
    Just guessing here, but the keyboard pwb should be the first thing to try.
    • DAKOTADAN
      • Jan 2011
      • 61
      Any ideas?
      I have had to resolder all the pin conections under the keyboard
      PC board, they get cracked loose from people stabbing
      at the keys to hard. Hope this helps
      Dan.
      • draph
        • 132
        Go into menu and check what the key beep length is. You can adjust the length of time a key needs to be held down before it takes effect.
        Had a customer play with this on an AR-208. Drove me nuts until I stumbled onto it.
          • 22997
          Dan.
          Machines of this era had a lot of problems with cold solder joints, either at the switches or at the board connector. Most of the time it's obvious (especially with a 10x lighted magnifier). Here's the test that I would do:
          1) Set your meter to the lowest resistance setting (usually beeps)
          2) Place your leads on the opposing legs of the switch, and press the switch 5 or 10 times. Readings of less than 0.5 ohms are preferable. If more I would replace the switch from a scrap PWB.
          3) If the switch meters OK, follow the traces out from your contacts points to the next solder joint, then meter again while pressing the switch. If you get resistance or intermittency you've got cold solder joints at the switch.
          4) Repeat many more times for the remaining switches. The ones that usually wear out are Print or Start, Stop/Clear, and Exposure Setting.
          In a pinch, you can relocate a switch from a location that you hardly ever use, to a function that you frequently use. Keep in mind that these little plastic switches are easy to cook to death with the soldering iron. Run the iron a little hotter, solder quick, and move on. If it doesn't take quickly move on, and try again when that leg has cooled down a little.
          I was just thinking today that the manufacturers must have improved the panels recently, because I have used only a few switches in the last 5 or 6 years. The last couple were HP LJ4200 paper size switches, on the paper size PWB. That model must be a dozen years old. =^..^=
          • kirkeb
            • Dec 2012
            • 31
            Winner!
            Thanks so much for all replies.
            (It drove me nuts as well. Why this would be a feature, or needed, is beyond me.)
            • draph
              • 132
              Hey, thanks for letting us know. I've been wondering what the out come had been.
