ARM317 with error A0-01
  • axyun
    • Aug 2007
    • 1323
    Have customer with AR-M317 which evidently has Data Security kit installed. When I attempted to add Fax kit(FX7) I got an error A0-01 when machine was powered on. Is there a way around this. If i were able to get the fax rom card from DSK and installed on fax board connector C11 would that do the trick?
    I don't suppose there is a way to disable data security through key operator function? Any assistance is appreciated. Frank/ActionPhotocopy
  • bilyahn
    • Dec 2006
    • 1470
    Re: ARM317 with error A0-01
    If you don't have the rom I'm pretty sure you can order from Sharp. You cannot disable DSK in system settings but you can remove it by replacing the roms with a regular set. Make sure that they don't want DSK because if you do this and then re-insert the DSK roms you will need the product key! Found this out the hard way, as usual! LOL
    Good luck.
    Bil
    • axyun
      • Aug 2007
      • 1323
      Thanks for the help Bil. I know they don't need the security as i just sold them the machine and thought the fax kit was already installed. So when i went to add it, as customer wanted fax option, i got the problem. Will keep you posted on results. Thanks again. Frank
      • danceswrabbit
        • Dec 2013
        • 65
        I ran into this exact same thing recently. If you do not have the rom that came with the dsk its a no go. You will have to replace the dsk to get one with the roms. I guess the roms are married to that dsk. we just gave up on it for that machine.
        • lenovos
          • Oct 2012
          • 141
          I think you also have to install the original image board the on that piggy backs the main board, If you choose to remove the DSK
          • axyun
            • Aug 2007
            • 1323
            Thanks for the helpful info guys. i will keep you posted. Frank
