AR-M451 H2-00 error
  • sorin
    • Sep 2010
    • 3
    [Error Code] AR-M451 H2-00 error
    Hello,
    This machine has about 400k copies and after i replaced upper and lower heat roller h2-00 appeard . I've tried with a different fuser unit and the error code is still there.
    Any help appreciated.
  • bilyahn
    • Dec 2006
    • 1470
    Re: AR-M451 H2-00 error
    Did you check to see if the thermocouple had popped?
    Good luck.
    Bil
    • sorin
      • Sep 2010
      • 3
      It was a bad thermistor on both fuser units. Thanks for the reply.
      Subject closed
