fusing belts source
  • Toner Boy
    • Aug 2007
    • 365
    fusing belts source
    Any feedback on Katun fuser belt kits for 2610N-5141N ?
  • Akitu
    Legendary Frost Spec Tech
    • Oct 2010
    • 2595
    Re: fusing belts source
    With all the problems these fuser belts had on launch, do you want to risk going to a non-OEM belt?
    • mojorolla
      The Wolf
      • 2624
      You took the words right out of my mouth!!!!
      • Toner Boy
        • Aug 2007
        • 365
        Ha, I figured that question would get you guys riled up . Just curious if anyone had some experience with them, have not ordered any as of yet, very few machines in the field so far. Saving cost is always a bonus IF they work, have limited our K parts to a couple drums and select fuser rollers over the last 10 years, most everything is OEM.
        Still curious if anyone has actually used these for some length of time.
        • foudl
          • Mar 2010
          • 138
          I have a couple of those in the field, i didn't have to change a fuser belt so far but i would like to know if some of you had prob. doing maintenance on those fuser.
          • harleyrider
            • Oct 2011
            • 348
            foudl haven't had any problems just takes longer to do than a fuser without the belt. Normally swap them out with a rebuilt fuser and when not busy rebuild in shop.Haven't tried any Katun belts and probably will not.
