Keep get this code on 1 machine checked ground, toner mix (118), drum unit, even replaced dv unit no change. Firmware is upto date. starting to run out of things to check any other ideas out there.
AR-M620N F2-02 ERROR CODE
Tags: None
Re: AR-M620N F2-02 ERROR CODE
When you changed the DV unit was it a new one or from another machine?"You can't trust your eyes, if your mind is out of focus" -- -
"You can't trust your eyes, if your mind is out of focus" --Comment
You might also check if the developer fan and filter were unobstructed, and vacuum out the ducts which fill with toner. You might also try turning the toner cartridge manually to find out if it will turn. I've found them seized. Usually beating on them will free it up. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
