MX 3100N
  • foudl
    • Mar 2010
    • 138
    MX 3100N
    I would like to know if there is a way to increase memory while sending to email ,customer complaint that with 20 pages the memory get full after 12 pages, of course there is a lot of graphics on each pages, so if i can increase the memory it would be great.
    Thanks for advices.
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: MX 3100N
    If the customer wants to send colour there is very little you can do apart from reducing DPI. If it is just black and white documents, if this model supports it, you could try Mono instead of greyscale.
    Albeit, they should be using scan to file for larger files, then send them from their computer.
      • 22997
      Re: MX 3100N
      Like ruben says, the limiter for scan to email is usually the attachment size allowed by the email account. For example, one of my accounts was limited to 2MB attachments. That can be as little as 20 monochrome, or 3 color images. The things you can do to reduce the size of the attachments are:
      1) default to monochrome rather than color scans. A color scan is 10x larger than a monochrome scan.
      2) reduce default DPI. For standard text 200 x 200 is adequate. For small text like legal documents minimum of 300 x 300. 300x300 is 2.2x larger file than 200x200.
      3) default to Text original type.
      And yes, scan-to-SMB and scan-to-FTP do not have these size limitations. =^..^=
      • divad2k1
        • Sep 2010
        • 147
        Re: MX 3100N
        4) Set compression to high
