MX-2310U Printing from USB
  • Madnhain
    • Dec 2012
    • 148
    Ok, so this has me baffled.
    When going to document filing there is no option for "Ex Data Access"
    The customer wants to print from USB but the option is not available.
    The option to turn this feature on/off does not exist in the system settings.
    I can scan TO the USB device.
    I updated the firmware so I know that it can read off the USB device.
    I have restored the machine to factory defaults.
    Any thoughts?
  • Akitu
    Legendary Frost Spec Tech
    • Oct 2010
    • 2595
    Re: MX-2310U Printing from USB
    Any thoughts?
    Can't recall if the 2310 comes with postscript or if this is a machine where it still had to be purchased separately and added. Postscript is required for printing from USB.
    • ruben
      The New Guy
      • Oct 2012
      • 1203
      The PS3 expansion kit is required to print PDF files from USB, jpg/tiff should be available as default.
      Make sure that USB Memory Direct Print is not disabled in System Settings and you are using the front USB slot. The USB device has to be formatted to FAT32 and be 32GB or less.
      • Madnhain
        • Dec 2012
        • 148
        The USB Memory Direct Print option doesn't exist in system settings. It's supposed to be in printer settings > default > USB Memory Direct Print However there's nothing there below Job Spooling option.
        I spent a good hour looking around the system settings for some other place it could be to no avail.
        Also looked at the web page of the machine with no luck there either.
        the usb is the same I use on all other machines, so it falls within the criteria.
        • mojorolla
          The Wolf
          • 2627
          It is a "U" model; everything is an option.
          • Ceechtay
            • Sep 2011
            • 158
            Correct. You need to have the Printer Expansion Kit installed (MX-PB14).
            Here is the page from the Operation Manual:
            Printing from a USB drive is a little later in this section of the operation manual.
            • Madnhain
              • Dec 2012
              • 148
              Stupid "U" Machines.... Grrr.
              Thanks guys. This was really torquing me.
              • bilyahn
                • Dec 2006
                • 1470
                Thankfully Sharp is no longer producing U version machines! So at least that particular nightmare will be resolved........
                Have a great weekend.
                Bil
