mx4112 smudging on letterhead
  • ash_572
    • Oct 2008
    • 523
    i have a mx4112 with 70kb/w and 30kcolour.
    sometimes on letterhead the text rubs off. plain paper is perfectly fine is perfectly fine.
    paper tray is set to letterhead and text is still rubbing off. i checked in simulation 43 to increase the temperature for letterhead but there is no letterhead option in sim 43. i can find heavy paper, plain paper etc but not letterhead.
    all consumables are within their lifespan.
    also i noticed when letterhead is printed, paper goes through the duplex????? i checked in system setting and cant change it. could this be the cause of rubbing off on letterhead.
    firmware is uptodate
    any help would be appreciated
  • sharphead
    • Aug 2009
    • 285
    Re: mx4112 smudging on letterhead
    Letterhead will always duplex as far as I know, what weight is the letterhead is it a particularly smooth finish?
    Worth trying the letterhead as a heavy paper to see if it makes any difference.
    I've had one customer's in which the quality of the letterhead constantly changes, (customers brother supplies the paper) ended up just running it on heavy one
      • 23009
      Interesting that your thoughts went that way, since mine drifted the other.
      Is this letterhead linen, or have a deep texture? It's a common problem to find toner poorly fused in the crevaces, but the high points fused just fine. The solution is the same however. Select Thick1 media type. Keep increasing thickness until it fuses properly.
      You get several benefits to using media type setting rather than just boosting fuser temperature.
      1) Copier speed decreases, allowing more time in the fuser
      2) Increased fuser temperature
      3) and when you resume using the normal media it doesn't wrinkle and jam at the higher temperatures.
      Back in the day we had additional options. We could adjust nipp width (fuser pressure). Most fusers now have no adjustment for fuser pressure, excepting perhaps an envelope setting for multiple layers of paper, which is a lesser fuser pressure. =^..^=
      • sharphead
        • Aug 2009
        • 285
        Maybe just different experiences. it's only ever been glossier smoother paper that's caused me problem in the UK, alas changing the paper type in UK heavy must be comparable to your Thick type paper. As it achieves the same result.
        • Josh93
          • Jul 2014
          • 47
          Also if paper thickness or toner fusing was an issue, you might have a build up of toner on your fuser cleaning web, in which case you might get some bad sounds coming from the rollers rubbing, and can also cause some dirty prints ect.
          Take the top cover off the fuser, and you can roll the web so the roller finds a cleaner spot. (don't roll it to far however because you will reduce its life!)
          Hope this helped, if it doesn't, then disregard
          • mojorolla
            The Wolf
            • 2627
            In System Settings, Device Control, Fuser Control settings set the paper weight to 23-28lb paper; default is 16-23lb.
            We do this on all new Sharps at setup; saves a ton of smudging calls.
