MXM-700 POD1_N
  • Ditchman
    • Feb 2011
    • 51
    MXM-700 POD1_N
    Hi Guys
    Hope someone can shed some light on this one.
    Machine is jamming on double sided copying, second side is not entering fuser correctly and then bottom half of page follows around with secondary transfer belt and lodges in behind it. Jam Code is POD1_N.
    Have tried new
    • Secondary Belt
    • Fusing Unit
    • Left Hand Door
    • Drum Unit
    • Exit Section
    • Firmware
    • Registration Unit
    Still happening, im a bit lost at this stage and hope someone can help
    Could i still have a problem with presssure adjustment on the new fuser?
    • 22997
    Re: MXM-700 POD1_N
    When you say exit unit, do you mean delivery/turnover? That's what I would have gone for.
    Have you tried different media? Does the paper curl? =^..^=
    • Ditchman
      • Feb 2011
      • 51
      Re: MXM-700 POD1_N
      Yes exit section is delivery unit
      Have also tried different paper, paper doesnt seem to curl, seems to "not enter the fuser" then bottom half follows around with secondary belt
      Thanks for input
        • 22997
        Re: MXM-700 POD1_N
        I thought that sounded familiar:
        Misfeeds (jam code POD1_N) intermittently. Occurs 18 times in 200K copies. The misfed piece of paper is frequently missed because it is behind the transfer belt, and discovered much later. Paper is diverted around the wrong side of the registration guide, and forced behind the transfer assembly. Mounting flange for the registration guide is too wide blocking vertical path. Grind down the mounting flange for the pre-registration guide until it is flush with the guide.
        It's been a little while since I recorded this, but I have a recollection of finding rough spots on the registration guide, where the support brackets mount. =^..^=
        • laitang
          • Nov 2012
          • 627
          Re: MXM-700 POD1_N
          Did you check/replace Transfer (TCCL) bias high voltage PWB?
          • Ditchman
            • Feb 2011
            • 51
            Re: MXM-700 POD1_N
            Could this be my problem?
            When my paper jams it has received the image of the drum?
            Thanks for help,
            • Ditchman
              • Feb 2011
              • 51
              Re: MXM-700 POD1_N
              Sorry, forgot to say. Yes i have also swapped over HV pwb
              • JTRAV
                • Aug 2014
                • 5
                Re: MXM-700 POD1_N
                I would start with the fuser drive unit. Have had multiple motors fail causing same issue.
                Good luck.
                JT
                • peps54
                  • Jun 2012
                  • 9
                  Re: MXM-700 POD1_N
                  I had the exact same thing on a MX-M753 with 800K images. Replacing the fuser drive unit took care of the problem..
