We have a Sharp MX-2615. The tech from the company that sold it to us changed the setting for the whole machine to print on the heavy paper when the second cassette is used. He said it is not the cassette that is set that way, but the whole machine. This was done after multiple times of repair because it was printing properly and affecting the fuser, I think it was.
In cassette 1 we use regular weight of 8.5x11. In cassette 2 we use ledger size of 24lb paper, always.
Every single time we wish to make a copy of ledger size we must select the paper size setting on the machine. half the time we forget and get small copies, throw them out, then try again.
Every single time we print ledge size we must remember to choose the print template we have set up to change the paper to heavy weight. If we forget and just print, it stops all other prints until someone goes to the machine and selects heavy weight.
We are wasting a lot of time and paper on this issue. If the machine can handle heavy paper, why does it make it such a hassle for the user? Surely, there is a solution which isn't a hassle every time we use this machine? We are under a 5 year contract, or we would just send it back.
And another thing - we can't get our ledger paper to staple.
Sure would appreciate any help, if anyone would be so kind as to do so. Thanks!
