MX-4101N colors not lining up on 11x17
  • CES_Imaging
    • Nov 2012
    • 65
    Just as the title says, on 11 x 17 color documents the color gets progressively more offset the further across the page you get. I've come here with this issue before on another machine. I was told the drive gear on the transfer belt could be cracked, but that is not the case with either machine. Any other suggestions?
  • ZOOTECH
    Senior member of CRS
    • 3375
    Re: MX-4101N colors not lining up on 11x17
    Fuser speed???
      • 22999
      Have you replaced anything, done any calibration? =^..^=
      • mojorolla
        The Wolf
        • 2589
        Run SIM 61-4 and measure the diagonal axis. ADJ 6 in the service manual.
        This is assuming you ran the proper calibration setup already......
        • CES_Imaging
          • Nov 2012
          • 65
          Adjustment 6 seems to have no effect. Attached is a sample (with title block removed for security.) On the right hand side there is a clear image. On the left it begins offsetting pretty drastically.MX-4101N_20140923_125612.pdf
          • ZOOTECH
            • 3375
            Adjustment 6 seems to have no effect. Attached is a sample (with title block removed for security.) On the right hand side there is a clear image. On the left it begins offsetting pretty drastically.[ATTACH]26537[/ATTACH]
            So to clarify, the left side is the lead edge or the trail edge?
            • ntbann
              • Jan 2012
              • 627
              I know there is a bulletin for fuser speed wrinkling paper. Could try bumping 48-6 by 5-10.
              • pmehreteab
                The most common cause for not lining up color copies is primary transfer belt drive gear. Either it is loose or cracked. If the gear is ok, adjust drum registration. Press system setting, admin password, type admin, device control, other setting. Go all the way down to registration adjustment and press "Auto Registration." Good luck.
                • harleyrider
                  • Oct 2011
                  • 348
                  this thread is allmost a year old. He probably has it fixed by now.
