MX-3115 paper size issue
  • Madnhain
    • Dec 2012
    • 148
    [Jamming] MX-3115 paper size issue
    Greetings!
    So, I've got a customer that had an MX-C311 and from tray 2 they were printing on 8 1/2 x 5 1/2 paper with no issues.
    Today, they upgraded to an MX-3115 and this same paper jams every time. (POD2_S)
    I made sure that I told the machine what size paper it was dealing with... Even tried it from the bypass tray with the same result.
    What else could it be?
    Thanks!
  • ZOOTECH
    Senior member of CRS
    • 3375
    Re: MX-3115 paper size issue
    Originally posted by Madnhain
    Greetings!
    Thanks!
    Are you feeding it SEF, sorry, I had to ask?
      • 23006
      I thought of that too. STMT-R, correct? =^..^=
      • mojorolla
        The Wolf
        • 2605
        A lot of the newer Sharp machines have the X and Y (length and width) backwards under the bypass tray settings. So X is really Y and Y is really X...if that makes sense.
        As already stated, that size must be run landscape as ANYTHING coming from a C311 would have been landscape.
        • Madnhain
          • Dec 2012
          • 148
          Yeah, I know it had to be asked. Yes, I tried orienting the paper in both directions.
          • ZOOTECH
            • 3375
            It has to be in the reduction mode - the paper won't feed between rollers otherwise; the _S indicates 'Still remaining'. If tray is set for statement R, you have another feed problem.
            • Madnhain
              • Dec 2012
              • 148
              I tried -R in the paper size settings. and I figured the paper would be too short to go the other way.
              the machine will feed other size paper with no problem.
              • Madnhain
                • Dec 2012
                • 148
                Problem Solved.... I growled angrily in the general direction of the tech that set the machine up.
