What am I missing?
  • draph
    • 132
    What am I missing?
    Installed a MX-NB10 network box on a MX-M200D. (first time doing this) Down loaded drivers from Sharp web site but all it prints is garbage. As if they are the wrong drivers. Tried down load from Sharp ca also. Same results.
    I'm I missing a step in the installation?
    • 23006
    Re: What am I missing?
    Did you install a PostScript driver or PCL driver?
    The MX-NB10 all by itself is PCL only.
    In addition, the MX-PK10 is required for PostScript printing. =^..^=
    • laitang
      • Nov 2012
      • 627
      Did you be sure to set the IP address of the machine?
      • draph
        • 132
        No, just using PCL.
        • Ceechtay
          • Sep 2011
          • 158
          In addition to making sure that all the connections are good and that there are no pinched cables, I would hold down the status button on MX-NB10 to print out the Printer Settings list.
          If that comes out garbled, it's probably a hardware/installation issue. If that comes over OK, then you can move to network/driver/software issue.
          • mojorolla
            The Wolf
            • 2605
            After option install, did you update firmware files via USB cable and software?
