Sharp MX-2600 C4-02
  • lenovos
    • Oct 2012
    • 141
    Sharp MX-2600 C4-02
    Hi all last Friday morning I got a call with the C4-02 code. I replaced the PTC unit with one out of another copier and reset the counter. The code cleared but now the pages are blank and jam around the registration rollers, each and every time. I also get F2-22 sometimes F2-24 CODES. I can watch the transfer belt, primary and some times it moves and some times it does not, I have changed out most of the boards. I also got a new PTC sensor in today and it made no differance. Because of the jerky movements of the transfer belt I also swapped out the outer clutch.
  • harleyrider
    • Oct 2011
    • 348
    Re: Sharp MX-2600 C4-02
    If the primary belt isn't moveing properly I would first check the drive gear.
    • lenovos
      • Oct 2012
      • 141
      Hi I figured out the F2-24, the magenta LED was not lighting up. We removed the screw and wiggled it a little bit. As for the transfer belt I have swapped it out and still no change. Paper mostly wants to jam at the base of the secondary transfer belt.
      • Akitu
        Legendary Frost Spec Tech
        • Oct 2010
        • 2595
        If you loaded your PTC incorrectly it stands to reason it may be causing some undue friction on your primary belt.
        • lenovos
          • Oct 2012
          • 141
          I checked that several times, I even ordered a new one but it did not change. It is kind of hard to install wrong, it would probably pop a code if it wasn't in right. It would also scratch the transfer belt.
