MX6201n Red line in the middle of Black and White prints and copies
  • ohightower
    • Aug 2014
    • 33
    [Misc] MX6201n Red line in the middle of Black and White prints and copies
    Im getting a red line in the middle of my Black and White copies and prints on MX-6201N I cleaned the transfer belt went away for a few days and came back
  • Josh93
    • Jul 2014
    • 47
    Re: MX6201n Red line in the middle of Black and White prints and copies
    More details, clean your scanner glass? copies or prints?
    • ohightower
      • Aug 2014
      • 33
      Prints and the customer hasnt been printing in color on black and white but its a red streak across the page when it prints i pulled out transfer belt it had a red streak also i cleaned it then it came back a few days later
      • Josh93
        • Jul 2014
        • 47
        Upload a sample if you have one so we can take a look What is the life on the belt and cleaning blade, did you have a look at your devs?
        Mess on the ADF scanner slit can be picked up as RED, even if its not, when doing colour copies, as the scanner used RGB opposed to CYM, causing a red line, is it possible your customer is scanning blk and white documents whilst hitting the colour scan?
        • spanky
          • Sep 2012
          • 468
          Does the red line show on the transfer belt after the cleaning blade and before the magenta drum unit?
          If so it is the transfer cleaning blade.
          • mikec320
            I would replace the magenta charge if its before the blade and cleans up. I have seen intermittent charge cause the problem.
            • duane@pbbsinc.com
              • Mar 2011
              • 77
              I have had customers scanning documents to folder or email for later printing. The lines of any color were the scan glass had something on it for the back side and they would save file with line already. The only way to tell if this is it is to create a new document or have customer do it and print it if it is clean then have them pull up the document in question and enlarge it and look at the whole document to see if there is any lines before printing.
              I finally pin pointed the time frame of scanned documents that all had a black line on this situation.
              If you default the printer to mono black and white the line will change to a black and white line when printing if it is a scanned in line.
                • 22999
                Good catch duane. =^..^=
