Sharp printer keeps rendering
  • cfragassi
    • May 2012
    • 9
    The printer keeps rendering when printing. I have to do a 66-10 reset to get it back printing. Im using pcl drivers.
  • NeoMatrix
    Senior Tech.
    • 3513
    Re: Sharp printer keeps rendering
    More info.
    Make and model number of the machine.
    What have you tried to repair the fault.
    • cfragassi
      • May 2012
      • 9
      Sharp mx 264. Updated firmware.
      • Josh93
        • Jul 2014
        • 47
        What are the jobs it is struggling to render? What application is sending the jobs, are the PDF, Docx ect.. What kind of network setup, what driver version are you running? What are the size of the jobs?
        Have you tried, re installing the drivers/updating? Using different applications? (EG adobe could be corrupting the job ect.)
        Take the machine off the network, print to it via crossover cable? Data could be getting help up on the network.
        Josh.
        • Akitu
          Legendary Frost Spec Tech
          • Oct 2010
          • 2595
          If you're using Adobe AcroCrap reader, try Foxit instead.
          • mttech
            • Mar 2014
            • 127
            I agree with trying printing with crossover cable. Had one recently that had same issue and was slow data transfer over network, but it is easier to blame copier than network. Also might want to see if sim 67-17, printer reset, has any affect. Sim 66-10 is for fax and image send clearing.
            • cfragassi
              • May 2012
              • 9
              Ok Thanks. Heading back here today.
              • joe_vanacker
                • Dec 2016
                • 28
                Try changing the tcp/ip port to lpr and portname lp
                • r3d343420
                  • Aug 2012
                  • 62
