ar-m451u firm. update
  • DINGO
    • 661
    Hi
    Today i try update a ARM-451U, and after finish the update the copier never more reboot, it is alwyas in the boot menu.
    And if i try update again show the message. [All NG]
    The firmware that i used is the version p1.17.
    Seems that the main flash do not update.
    I do not have another Arm-451u, but if i change the main flash with a 451N, the copier already reboot, but gives me e7-03, because do not have hdd.
    So, any help thanks in advance.
  • ZOOTECH
    Senior member of CRS
    • 3375
    Re: ar-m451u firm. update
    Originally posted by DINGO
    Hi
    Does the machine have the DSK or print option installed? If so, you may have the wrong frimware.
    • DINGO
      • 661
      Hi friend
      Thanks for you reply.
      Weel the copier has print network, but no have dsk, hdd and no expansion dcanner kit to.
      There are are Arnc7, so i have the firmware version p1.17 for Arm-451u with arnc7, and before a try reflash the copier i cheked in the sm 22-6, and the version that was instaled is the version that i have to, p1.17.
      I only try reflash the copier because there are a litle issue with the oem toner box, do not detet it, but and this is funy, detete the compatibles boxs.
      Now, may be i do something wrong, i do not know what?
      How i can fix this, i have not another main flash or copier version U, only n
      • DINGO
        • 661
        Mate, one question, if by mistake i flash the copier with a wrong firmware for ex. With a N models firmware, after i can flash with a corret firmware?
        May be ,i by mistake have sent a wrong firm. (n1.17, n models), i do not know if is because this that now the corret firm. (p1.17) gives me always All NG.
        • bilyahn
          • Dec 2006
          • 1470
          You can re-flash this with the correct firmware, it should work. You were using the section B update procedure correct? What's the worst that can happen right! Or if you have any other ROM's available (doesn't matter which version) you can reflash each individual ROM using slot CN6 per rom update procedure SM section 12 starting at page 2 section C.
          Be advised if you do it this way any product keys that have been entered may be lost. Had this happen to me when I screwed up a ROM update with a DSK kit installed. After I corrected the problem I had to re-enter all of the product keys to get it to work correctly again.
          Good luck.
          Bil
          • DINGO
            • 661
            Hi mate
            Unfortunaly, i already try re-flash with the corret firmw. That is v p1.17, because i hsve s room Ar-p20/ar-cn7, but without sucees, always i get the result. ALL NG., and the copier is always in the boot menu, not work.
            And, for do a flash copy i do not have another U model, i have a lot ar-451 but N models.
            Thanks mate
            • bilyahn
              • Dec 2006
              • 1470
              You can use your N models machines to flash U ROMs if you use the CN6 slot and the correct firmware update procedure. Doesn't make any difference as you are only updating the firmware to that slot. Have done it this way a loooooong time ago but it works just fine in a pinch.
              Have a great day.
              Bil
              • DINGO
                • 661
                Have a great day.
                Bil
                Ok Billy
                i already do it, funny that the upgrade whit the corret firm. show me the message OK, but whent i put in the copier again, always stay in boot menu, not work......
                if i upgrade with the firmware from main N models flash room, the copier already start, but of corse show me the message E7-03 , becuase there are not hdd , and if i put a normal IDE 40GB hdd , do not work to.
                So i m looking for one AR-m451U, for take the flash room and make a copy, (clone), mi problem is because i only have N models.
                many thanks mate.
                • bilyahn
                  • Dec 2006
                  • 1470
                  Do you have a fax unit attahced to this? Had that happen once with fax attached. Needed to turn both off before it would return to normal state. It was pretty weird but something I always remembered after that! LOL
                  Good luck.
                  Bil
                  • DINGO
                    • 661
                    Ok mate
                    No, no fax
                    Thanks again
