MX-2615 & MX-2640 printing issue with IMC
  • MHeon71
    • Oct 2008
    • 489
    The copier is a MX-2615. From the admins PC, she is not able to print diagrams of the scene of the accident. From a detectives PC, he is able to. They are both Windows 7 64 bit and they print through the server. To me, that would rule the copier and driver out of the equation. Has anyone seen this issue and know the resolution?
    IMC says that it needs to be a 32bit driver, but I do not think that is the issue.
  • faxman28
    • 435
    Re: MX-2615 & MX-2640 printing issue with IMC
    need more info, is user accounts turned on on the copier, what happens when they print, does job make it to the 2615 or does the printer dump the job right away.
    • MHeon71
      • Oct 2008
      • 489
      No user codes or retention printing involved. The text portion of page is printed, but the picture portion is blank.
      • mojorolla
        The Wolf
        • 2627
        Try this setting:
        Could also try the PS driver.
        • MHeon71
          • Oct 2008
          • 489
          I will try that your settings tomorrow or Monday. Thanks for the advise. I will get back to you.
          • MHeon71
            • Oct 2008
            • 489
            Thanks Mojorolla, Checked the box for Use driver to render JPEG was the answer.
