MX-2640 H4-01
  • orghost
    • Oct 2013
    • 8
    [Error Code] MX-2640 H4-01
    I have a new less than 2k prints that comes to ready, works fine, but when left alone throws an H4-01 code for a low temp error on a THS. I can put the fuser in another machine and it works fine. when I put in the fuser from the other machine it still throws the same code. If I reset it it works fine until left alone for a few minutes.
    Any ideas???
    • 22927
    Re: MX-2640 H4-01
    What does the power quality analyzer tell you? =^..^=
    • orghost
      • Oct 2013
      • 8
      Re: MX-2640 H4-01
      I am in a lab environment, I have two machines right next to each other on dedicated circuits, and yes I have checked and double checked the power.
        • 22927
        Re: MX-2640 H4-01
        Laboratories don't have power problems? =^..^=
        • orghost
          • Oct 2013
          • 8
          Re: MX-2640 H4-01
          FYI, I am a 3T technical instructor, I have tried the obvious. Right now I am in the process of changing out the PCU PWB.
            • 22927
            Re: MX-2640 H4-01
            Seems logical to me. I try not to make any assumptions about any individuals skill or lack of skill level. And yes, I am the master of the obvious. =^..^=
            • orghost
              • Oct 2013
              • 8
              Re: MX-2640 H4-01
              PCU-PWB was the problem...the issue followed the board. Now all I have to do is figure out which student to blame...
                • 22927
                Re: MX-2640 H4-01
                That should be easy enough to figure out. I always found it annoying working on the class machines with most of the screws missing, and the rest stripped. And the mystery parts stashed in the stand 'cause they couldn't figure out where they go.
