L4-57 Error Help
  • teklife256
    • Sep 2012
    • 164
    L4-57 Error Help
    Working on a MX-5001N with a L4-57 error. The error code relates to Toner cooling Fan Trouble per the manual:
    Cause
    When the toner cooling fan is operated, the fan
    operation signal is not detected within the specified
    time.
    Toner cooling fan trouble.
    PCU PWB trouble.
    Connection trouble of the connector and the harness.
    Check & Remedy
    After turning ON the power, check to confirm that the
    fan is rotating.
    Replace the toner cooling fan.
    Replace the PCU PWB.
    Check connection of the connector and the harness.
    To this point I have tested the fan in 6-2 (CAFM) and replaced PCU PWB as well as checked the connections to no avail. The code can be cleared with sim14 but returns. The machine will make 15-20 copies before the error returns. To this point I have not replaced the fan because it tests fine in sim mode.
    Any help would be appreciated.
  • laitang
    • Nov 2012
    • 627
    Re: L4-57 Error Help
    Originally posted by teklife256
    .....To this point I have tested the fan in 6-2 (CAFM) and replaced PCU PWB as well as checked the connections to no avail. The code can be cleared with sim14 but returns. The machine will make 15-20 copies before the error returns. To this point I have not replaced the fan because it tests fine in sim mode....
    1/ There're two Toner cooling Fan!
    2/ A fan can rotate good but the feedback signal to PCB is not!
    • harleyrider
      • Oct 2011
      • 348
      seen it a few times and new fan was the fix
      • skookumchuck
        • Feb 2012
        • 62
        What they said!
