MX-6240 3rd one with a U5-16 error code
  • Sharptech0892
    • Aug 2011
    • 79
    [Error Code] MX-6240 3rd one with a U5-16 error code
    I have had 3 different mx-6240 have a issue with u5-16 which is doc feeder cooling fan issue, anyone else having this problem? All 3 times its been the smaller pwb board in the document feeder, don't remember the part number off the top my head.
  • spanky
    • Sep 2012
    • 468
    Re: MX-6240 3rd one with a U5-16 error code
    I had the same issue with one of my machines.
    The fan stopped running and when I replaced the fan it ran at high speed all of the time.
    I then had to replace the board you mentioned.
    You may want to replace the fan and board as a pair.
    • Sharptech0892
      • Aug 2011
      • 79
      Yep, I also replaced pwb and fan as a set, going to open a ticket with sharp since it's the 3rd one I've had.
      • coopers1305
        • Nov 2014
        • 49
        CPWBN1982FCE1 DSPF driver PWB
        • copierdude1114
          • Dec 2015
          • 29
          I had this once, SOMEHOW, SOMEWAY, a paper clip got into the ADF and was sitting on-top of the PWB , removed it and everything was right in the world.
