3332 MX-3100n & MX-2600n scan to email
  • ohightower
    • Aug 2014
    • 33
    [Error Code] 3332 MX-3100n & MX-2600n scan to email
    Getting error code 3332 when setting up scan to email on A MX-3100n and MX-2600n no matter what I do it wont connect I've set up atleast 20 other machines no problem they work fine but I have 3 machines i cant get to connect on cable network or dsl network. I even tried to cloning the settings from another machine that was set up and working correctly and still wont connect anyone else had this problem? or know any solutions thanks!
  • mojorolla
    The Wolf
    • 2622
    Re: 3332 MX-3100n & MX-2600n scan to email
    Try running simulation 67-17 to clear out the cobwebs.
    • ZOOTECH
      Senior member of CRS
      • 3375
      TC 67-17 after you save your network settings.
      • ohightower
        • Aug 2014
        • 33
        Thanks guy but 67-17 didnt work either still giving me 3332 error
        • ohightower
          • Aug 2014
          • 33
          I got it to work I had to clear all the memory with 88-1. When using this be carefully because it will clear everything off of your copier so make sure you back up everything before using 88-1 but thats what worked for me.
          • MattL
            • Apr 2012
            • 97
            Is the mail server in question set to receive incoming connections from the IP of said copier? Sounds like it might be getting blocked hence why it not working and giving you that code.
