Sharp MX4100n Lead edge off
  • Deer John
    • Aug 2013
    • 21
    The lead edge of copies from tray 1 is off (late) by about 1/2 inch.
    I have tried the adjustments in the svc programs including paper buckle to no avail. It does it thru the SPF as well as on glass. Let's start with this question:
    what specifically is the most effective adjustment program for this problem?
    The array of adjustments is bewildering and I may not be seeing the forest for the trees so to speak.
    I appreciate the input.
  • ntbann
    • Jan 2012
    • 627
    Re: Sharp MX4100n Lead edge off
    Did you run a 50-22?
    • faxman28
      • 436
      adj 17 and 18A in the manual(adjustment section chapter 5) or do 50-28(auto adjustment ,27c in chapter 5). when you do the adjustment does your lead edge change ? if not could be scanner or pcu pwb, depending on copy or print mode .
