Re: Error code C4-00
PTC error
Replace PTC or change PTC disable in switch mode
Error code C4-00
Plus one on the two clutches on the rear of the main drive unit, cured C4-00 on one of my MX2310, tried all of the suggested remedies for this fault before trying the clutches as I could hear a slight rattle with them and it fixed it in minutes.Leave a comment:
We replaced 2 boards in the last week to fix the problem, after the new PTC didn't fix the problem. Before you replace this board check the number listed on your old board, if it is the new board already in the machine, then maybe check the previous post about the slipping
clutches. Good Luck.
Dan.
Thanks to all for their help.
The Beagle Bow..WowLeave a comment:
Finally solved the problem.Is TC pcb out of position.
I miss read bilyahn and faxman28 regarding the TC PCB. There is two HVT PCB and i just look into the MC/DV pcb only.
Thank you once again for everyone info.Leave a comment:
Another tech, had this code on a mx3100n, after changing out the parts listed in manual
, with out problem being solved. He changed out the DC-pwb. problem solvedLeave a comment:
Dan.
Were yours on the mx-3640 series machines? and did they have the constant c4-00Leave a comment:
Dan.Leave a comment:
Has anyone had success replacing the TC-PWB pn# RDENU0154FCP2 on a mx-3640n to solve a c4-000 code.
I have tried replacing the PTC with no luck. Machine has 40k color 90k b/w and it happens in color or b/w mode every time. Shes down.
Thanks in advance.Leave a comment:
I know this is late but I had this problem and nothing the book said was the problem. The ptoblem was the clutches in the back of the machine that control the switching of the transfer unit from black to color were slipping. Run the machine with the front door open and the waste bottle removed and watch the cam on front of transfer unit. On mine when it would switch to color you could watch the cam move as the clutch is slipping and not holding that position then throw the code. I replaced both clutches to cure problem.
Thank you very much.Leave a comment:
I know this is late but I had this problem and nothing the book said was the problem. The ptoblem was the clutches in the back of the machine that control the switching of the transfer unit from black to color were slipping. Run the machine with the front door open and the waste bottle removed and watch the cam on front of transfer unit. On mine when it would switch to color you could watch the cam move as the clutch is slipping and not holding that position then throw the code. I replaced both clutches to cure problem.Leave a comment:
Thank you everyone for the info,may be should take back the machine for checking.Leave a comment:
Haven't seen this yet but will keep this info in my back pocket.Leave a comment:
there is a bulletin out in the U.S. for c4-00 errors and it does list the mx-1810(which is not sold here) and mx 2610,2615 and so on. for a updated TC pwb to help correct c4-00 errors. check sharp support in your country.
RDENU0154FCP2 this is updated p/n, looks like common part for all of sharp markets. again check locally.
RDENU0154FCP2 this is updated p/n, looks like common part for all of sharp markets. again check locally.Leave a comment:
