OCE CM2510 (Sharp MX2300)
  • Reed
    • Feb 2011
    • 259
    This machine keeps showing a paper misfeed after it starts to warm up. It shows to remove paper @ POD1 and at the registration. But when I go into the service mode neither of those switches are highlighted as if there were some paper blocking them. I have simulated at jam at these areas and the machine will immediately show a jam upon start-up and doesn't try to warm up. The curious thing is the machine will cycle and warm up for a bit before showing the paper misfeed error. I have cleaned and tested all the sensors in the service mode. I have also reset the paper jam errors and it keeps shows there was a misfeed at POD1. Thanks in advance any help would be appreciated
  • DavePo
    • Jul 2008
    • 303
    Re: OCE CM2510 (Sharp MX2300)
    Replace the fuser unit. Or rebuild it with all the thermistors, also check the thermal breakers.
    • Josh93
      • Jul 2014
      • 47
      Out of curiosity, what is the actual jam code? Pod_1N ect?
      • Reed
        • Feb 2011
        • 259
        Yes, that was the exact code
        • Reed
          • Feb 2011
          • 259
          Thanks for the advice. I went out and rebuilt the fuser unit with thermistors. Machine still had the same problem I pulled out the fuser and checked the thermal breakers. I pushed the button on the back of one of the thermal breakers and I heard a snap. After that I had no more problems. I wouldn't have thought the thermal breakers would have caused this problem. But I am glad it worked!!
          • Optima Family
            Hello Gentlemen,
            Does somebody know if the OCE CM2510 & the SHARP MX2300N use the same toner cartridges?
            Thank you.
