mx-3501 E7-11 code
  • dcooper
    • Nov 2014
    • 37
    mx-3501 E7-11 code
    Hi I am new on this site but I am having a problem with a MX-3501 with code E7-11 and it locks machine up.
    I have installed a scanner board from a working machine with no help. I cleaned the white pad under glass with alcohol.
    I disconnected flat white cable that goes to scanner on both sides and reconnected them. No help. Has anyone else come
    acrossthis problem and have any suggestions. Thanks for your help in this matter.
  • Akitu
    Legendary Frost Spec Tech
    • Oct 2010
    • 2595
    Re: mx-3501 E7-11 code
    E7-11 on those machines usually translated to a HDD failure. Replace HDD and reinstall firmware to fix.
    • faxman28
      • 435
      have you replaced the ccd unit ? how does the exposure lamp look.
      • mojorolla
        The Wolf
        • 2639
        Check the GAIN in simulation for the CCD. If it is up around 10, the CCD is the cause.
        • tee
          • Aug 2014
          • 79
          I try to clean mirrors, lamps, and all optics. Then I
          use sim 63-2 and perform both glass and duplex.
          If it completes OK then all is good.
