MXB201D Distorted Fax Monitor
  • chris_c
    • May 2012
    • 34
    [Misc] MXB201D Distorted Fax Monitor
    I've got a Sharp MXB201 that is distorting the fax line monitor. I've already updated firmware, did an 88-3 fax clear, replaced the fax pwb, speaker, and harness, and I even put the new fax pwb on a different machine and still have the same issues. The customer uses a long distance code, so they have to hear the prompt to input their code, but they cannot hear it. Its not the phone line. I've tested with a phone, and a samsung fax and its clear as a bell. Brought the copier in shop, and even on our fax line I still get a distorted monitor. Any suggestions?
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1888
    Re: MXB201D Distorted Fax Monitor
    Are you using a 2 wire phone line ? Anything more than two has generated odd problems on multiple manufacturers equipment for me.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • chris_c
      • May 2012
      • 34
      Yep. 2 wire on location and here in our office. Our dealer has a tech support line and I was told to double check the lines.
      • DavePo
        • Jul 2008
        • 305
        We have probably over a hundred of these out and all have crappy line monitor. Also have issues of memory filling up and locking machine until TC 66-10 clear.
        • chris_c
          • May 2012
          • 34
          The issue was that a vocal prompt (asking for a long distance code) had a much lower volume than the dial tone. Basically, nothing can be done.
