Sharp 6500 with PE 10 Fiery
  • spanky
    • Sep 2012
    • 468
    This machine will tell the customer to remove paper from the stapler compiler, but only on the Fiery screen.
    If I go to the copy screen it does not tell me there is paper there and I am able to run copier.
    I go back to the Fiery screen and the message is still there to remove the paper.
    Have installed the Fiery software on the server again and it corrected the problem for a short period of time, had come back.
    I can reboot the Fiery and the message will disappear.
  • igi
    • 1507
    Re: Sharp 6500 with PE 10 Fiery
    hi
    make sure you got
    the latest firmware for the copier
    and latest fiery updates
      • 23007
      I take it on very good authority that the fix for this is installing Service Pack 2, with patch FIT156263 "false misfeed in CWS, no jam in machine".
      Just reloading system software isn't enough. There are a whole heap of patches which need to be also applied (in order) after applying SP2.
      Print out the system updates log to confirm all patches & SP's are installed.
      Personally, I don't see Sharp much any more, but my source is very reliable. =^..^=
      • DavePo
        • 305
        I have a similar situation except it is Command Workstation thinks Upper Stacker Door is open. Am in process of reloading system software as two of the patches installed twice.
        • mojorolla
          The Wolf
          • 2609
          The new Fierys are shipping with Fiery version 1.1. This version has the SP1-SP3 patches built into it, if you are going to spend the time reloading, use 1.1. After installed, hook into the internet and it will update itself like Windows updates. I believe with 1.1, the only updates are for banner printing issues and a new version of Command Workstation.
          Over a year after release, still wrought with issues.....ugh.
          • Tonerbomb
            AutoMajical Resolutionist
            • Feb 2005
            • 2589
            Try running the latest version of cws??
            Mystic Crystal Revelations
            • spanky
              • Sep 2012
              • 468
              Fiery update corrected problem
