sharp mx m700 exit delivery jam
  • pontiac
    • 420
    Paper jams at the first set of rollers of the exit assembly, when u manually turn the exit knob it feels like its is binding, after removing and checking drive gears and sub assemblies i realized when power is off the rollers turn freely on the exit unit, when u open the copier to clear jam from the exit unit first rollers are still binding. I have to power off and on for rollers to turn . Any ideas thanks
  • faxman28
    • 435
    Re: sharp mx m700 exit delivery jam
    it's probably the roller bearing in delivery unit(i think it's a one-way bearing) It's better to replace the delivery unit ,the heat from the fuser takes it toll on the sensors, plastic guide rollers and so on in the delivery unit.
    • pontiac
      • 420
      Thank faxman28. I returned with a another unit and had the same jam . When removing the jam I slid the delivery unit out and the rollers became free the metal drive from the engine was still binding when I turned it by hand and it had power even with side unit opened. when I turned the power off it turned freely. ?
      • igi
        • 1507
        hi
        what is the jam code
        in sim 22
        • pontiac
          • 420
          Originally posted by igi
          hi
          in sim 22
          SORRY for late reply didnt have access to copier . Copier did not register jams or errors after 3rd reset l4-30 showed up on screen and when I replaced controller fan everything started working again. I am stumped. Thanks for replys.
