MX2600 L4-16 error
  • harps05
    Field Service Engineer
    • Mar 2012
    • 112
    MX2600 L4-16 error
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: MX2600 L4-16 error
    Looks like the sensor is working, so I would look at the motor side.
    • igi
      • 1507
      If motor is not turning , Check Motor , and drive signal from Toner Motor Control PWB
      clean or replace.
      fuses on dc-power/check too
        • 23003
        I don't see Sharp very often any more, but I have it on very good authority that you need to replace the Toner Motor Driver board. This board is located above the Main Drive Unit and has a direct harness to the Fuser Pressure Drive release motor.
        Parts Guide section 41, item 48.
        "Have had this many times. Usually occurs when the motor harness is plugged in while the main switch is turned on (machine off at sub-power switch). Happens to the techs a lot!
        Have seen it, had it myself and traced the circuit diagram to that board."
        I hope this helps. =^..^=
        • harps05
          • Mar 2012
          • 112
          Thanks for the ideas Guys. Will give them a try in the morning and report back.
          Thanks again
          • harps05
            • Mar 2012
            • 112
            Thanks for the help Guys. I replaced the Toner Control PWB and the case is now closed. The brains trust on this forum is invaluable.
              • 23003
              Congratulations on your success. =^..^=
