mx5112 weird network connectivity issues
  • justicar
    • Oct 2014
    • 6
    The machine is connected to the wall outlet with static ip but it doesnt get any response and the nic lights is not flashing. however if i connect to it via laptop using a crossover cable the lights starts flashing and i can ping / connect to it. I have confirmed that the wall outlet is not the problem.
  • bilyahn
    • Dec 2006
    • 1470
    Re: mx5112 weird network connectivity issues
    It's probably not the copier unit. I would try 2 things. First wheel it over to a different wall outlet and try a different Ethernet cable and see if you still cannot connect to their network. Also try a crossover cable if that step did not work (had this happen one time where a regular Ethernet cable would not work but a crossover cable would). Go figure.... Depending on the results let us know and we can try some other things that might be appropriate to your issue.
    Good luck
    Bil
    • Akitu
      Legendary Frost Spec Tech
      • Oct 2010
      • 2595
      Sounds like an IP address conflict on their network.
      • mojorolla
        The Wolf
        • 2604
        Plug your laptop into their network, check for link light and internet access.
        As mentioned about duplicate IP addies, unplug the network cable from the machine and ping the copiers ip addy from a workstation on the network. If you get a response, it is from something other than your machine.
        To check the machine:
        Run the internal ping command (127.0.0.1) logged in as admin in Network Settings. If it cannot ping itself, you most likely have a bad MFP board.
        Check the device name. I leave it as the default mumbo jumbo. It does not seem to like symbols and punctuation marks so much.
        Check the DIMM chips on the MFP boards. SIM 60 to test the chips.
        Clone the device and run SIM 67-17, print controller memory dump, re-clone.
        Rinse and repeat.
        • justicar
          • Oct 2014
          • 6
          Rinse and repeat.
          Thanks for the checklist! I tried the internal ping command which didn't work. Then i switched to another mfp board from another working 5112 and the internal ping command didnt work. I tried bypassing the ip-conflict by putting it in dhcp mode but when i print out NIC-list it shows ip adress as: -------------------
          DIMM chips was okay. Didnt try 67-17 not really understand what u meant. Btw i noticed now the nic lights flash 2 times when the machine starts and then it goes black.
          • tee
            • Aug 2014
            • 79
            I had a switch with a intermittent port cause the same thing.
              • 23003
              Maybe you have a partially mis-wired network connector at the wall, and the laptop can overcome it. What about the crossover cable and laptop? That's the ultimate test. =^..^=
              • Michmich123
                • Nov 2013
                • 24
                I think There is a Problem with the autosensing for networkspeed .
                Try to fix the networkspeed with Sim 55-03 sw 6 .
                bit 1 from 0 to 1 autosensing Off
                bit 2 : 0= 100 , 1= 10
                bit 3 : 0 = fullduplex 1= halfduplex
                bit 4 : 0 = 100 , 1 = 1000
                we have a Lot of machines fixed with These setting.
                Regards
                michmich
                • hellcat
                  • Jan 2012
                  • 124
                  Chances are it is either a miswired wall mount or a bad switch on the router/hub. Have had this happen a few times. Like said previously double check it at another port in the office and you already tested it via crossover cable so there is nothing more for you to check really. Its on their network side.
