MX5111 pulling developer
  • copyguy1
    • Jul 2011
    • 142
    Have had issue with pulling the black DV. Have replaced Drum unit DV unit and both TRansfer belts. It does this about every 2 months. Thanks for the help.
  • tee
    • Aug 2014
    • 79
    Re: MX5111 pulling developer
    Try the high voltage connector assembly on the rear frame.
    • michaelc
      Field Tech
      • Mar 2011
      • 590
      Has the machine been fitted with the MX510MK/MX51GUSA parts or MX310MK/MX310GUSA parts.
      It didn't say that I couldn't do it in the manual.
        • 23007
        Typically developer dumping is caused by primary charge faults. As SOP when we see developer dumping, we'll replace developer, drum, blade, and primary charge parts, all at the same time. It resolves most situations. =^..^=
        • vos.3305502137
          • Feb 2015
          • 7
          Try Tech bulletin MFP-TB 559. Change in dv cover. PN DUNT-8598DS14 for black cover.
          • jp74msj55
            • Oct 2014
            • 149
            Part number? Have you tried this your self. Thanks.
            • mansart
              • 852
              Yes the above mentioned bulletin is correct. increased airflow to developer.... increased airflow keeps the dv cooler.
              The pull occurs as the dv heats causing the toner to "clump", this causes excessive dusting on the charge grids which in turn causes the dev. pull
              • JLSam
                • Jun 2015
                • 605
                Here you go!
                • repn1999
                  • May 2010
                  • 310
                  I have seen this alot in the field. Sharp hotline recommended replacing the drum units with the newer style used in the 5141. That helped but did not resolve the issue. What did fix the issue was using SHARP waste toner containers. We had been ordering from K**** and their bottles seemed to fill up too far and waste toner would back up. When we torn down the drum units on the units that pulled we found toner dusted mainly on the front side of the main charge grids in the drum units, for about an inch or so. We observed this on about 50 machines, both 5111 and 5141 types. Hope this helps. repn1999@yahoo.com
                  • boutn
                    • Jun 2016
                    • 547
                    No more problems since then? Because this is exactly what we have right now!
                    See my post...
                    http://www.copytechnet.com/forums/sh...per-issue.html
