Sharp simulation mode
  • fuser101
    • 13
    New to Sharp model MX-M503
    Is it possible to be in simulation mode and run copies at the same time?
    I have been told this is not possible.
    I do have a service manual but have yet to look in to this myself.
    Many other OEMS have this ability. I need to monitor the temperature while the copier is running.
    thanks,
  • igi
    • 1507
    Re: Sharp simulation mode
    yes aging test
    sim-7
    • fuser101
      • 13
      Thanks for your help it is appreciated. I just quickly reviewed sim-7 in the SM will I be able to monitor the temp of the fuser or just the warm-up time?
      thanks again
      • igi
        • 1507
        thanks again
        just warm-up
        you can change the temperature with sim-43,but you cannot measure.
        • igi
          • 1507
          thanks,
          why whats happening to your machine
          • fuser101
            • 13
            I am trying to verify the operating temp of the fusing unit in order to evaluate some bearings and AM rollers that I have been sampled.
            thanks for your help,
            • mojorolla
              The Wolf
              • 2584
              44-14 will show temperature and humidity reading both internal and external.
              • fuser101
                • 13
                Right, but am I able to access 44-14 while the copier is running a long run in order to monitor the high and low temp fluctuations?
                When I enter in to 44 as the copier is running it stops the copy run at that point so then when I get sub mode 14 all i can do is see what the temp is at in stand-by.
                I do appreciate all of the suggestions and help.
                thanks,
