mx3100n color issue
  • majx75
    • Nov 2014
    • 13
    [CQ] mx3100n color issue
    Hello! I have a mx3100n that is giving issues with gray half tones. no matter if it is a scan or print job, if the job is done in color mode, the gray tones have a cyan/blue tint to them. I have done copy and print calibration to no avail. If the job is done in b/w, it looks great. drums and developer have been changed too. Any info would be great. wanna pull whats left of my hair out!!!
  • sharptech
    • May 2011
    • 40
    Re: mx3100n color issue
    when you say you have done calibration what simulations did you perform and in what order?
    T.G.G.
    • majx75
      • Nov 2014
      • 13
      after the developer change, i did 25-2. then performed 46-24 then 67-24
      • allan
        RTFM!!
        • 5459
        I sounds like you're only getting compensate black (CMY mix) and noting from the black drum.
        Whatever
        • majx75
          • Nov 2014
          • 13
          Right? if you send a print job grayscale to the copier, it looks fine. black copy off platen looks fine. do the same in color and it cast a cyan/blue tint.
          • majx75
            • Nov 2014
            • 13
            when the transfer belt engages the color drums, couls the black drum be out of position or too far away from the belt?
            • Akitu
              Legendary Frost Spec Tech
              • Oct 2010
              • 2596
              You missed a few components of the colour calibration. You should be doing a 44-27 to clear your half tone values; if you don't have a good half tone you'll never have a good full tone. There's also 44-2, 44-6, 50-28 and 50-22 to do.
              The MX3100 series also supports the full calibration code of 46-74 which will do the complete calibration procedure.
              • majx75
                • Nov 2014
                • 13
                Issue resolved.......was an exposure setting in the system settings. it was set to 8 instead of 5 wich is default. previouse tech who took call failed to mention...
