Sharp ARM 700 Fax
  • Dean
    • Feb 2007
    • 19
    Sharp ARM 700 Fax
    I had to take the fax board off a machine in the office and put it on a customers, when I press the image send button it says to turn on the fax switch but I cant find one. I have looked through the 700 service manual but I do not have one for the fax board.
    Can anyone help? Thanks
    Dean
  • travi
    • Jan 2008
    • 129
    Make sure the country code in Sim 66-2 is set to USA. The code is 10110101.
    • Dean
      • Feb 2007
      • 19
      I already checked that. Thanks though.
        • 23009
        You also need to clear the fax memory. I'll pretty sure that's sim 66-10. =^..^=
        • vlad_
          • Jul 2008
          • 98
          Question in a theme. Why it is necessary to clear memory of a fax after installation? (So write to instructions on installation)
          • DavePo
            • Jul 2008
            • 305
            Have you checked the outputs at the power connector that the fax box connects to?
