Sharp MX-2300 (Badged as Oce CM2510) Magenta background
  • IRHNN
    • Apr 2025
    [CQ] Sharp MX-2300 (Badged as Oce CM2510) Magenta background
    Color prints from the network, and color copies have a uniform magenta background.
    The problem gets worse on longer runs. Starts out with a faint magenta tint that gets darker as the run continues.
    Copies of a color test chart look pretty good except for the background.
    Blacks are black, the image is sharp and all of the colors are good.
    Black and white prints and copies come out clean with no background.
    The only thing I've tried so far is calibration from Admin mode.
    It cleared up for about 20 copies and then came back.
    I believe the developer is fairly old. Possibly more than two years.
    I have new developer available.
    The primary image transfer belt is only about 8 months old and volume on the machine is fairly light.
    Any suggestions or questions to help direct me will be most appreciated.
    Steve
  • Vulkor
    • Jun 2009
    • 942
    Re: Sharp MX-2300 (Badged as Oce CM2510) Magenta background
    As old as that unit is I've seen this happen before. I've had to replace the DV Units themselves.
