ar_m350 errors
  • DINGO
    • 661
    ar_m350 errors
  • swagreis
    • Jun 2008
    • 92
    Re: ar_m350 errors
    Try to change MFP first may it is
    If not change power board
    I think one of them is the defect item
    • DINGO
      • 661
      Re: ar_m350 errors
      thank you mate, but i already test with another mfp and main board to
      thanks anyway
      • swagreis
        • Jun 2008
        • 92
        Re: ar_m350 errors
        So it may be from cables and connectors of machine may there is a bad connector pin or a wire
        Try to get a machine frame from a scarp machine
        • ntbann
          • Jan 2012
          • 623
          Re: ar_m350 errors
          We have changed the wire harness on the adf many times. The one that goes from the feeder to the adf control pwb.
          • DINGO
            • 661
            Re: ar_m350 errors
            thank you to Down Under
