mx3640 l8-20
  • sharphead
    • Aug 2009
    • 285
    mx3640 l8-20
    There is a technical bulletin on this. It says to take a USB backup via 00-11
    Then a trouble clear then too disable a number of ports.
    I updated the firmware. But wasn't sure which ports to disable and are they all in network settings
    • 23006
    Re: mx3640 l8-20
    I have it on good authority that the L8-20 trouble code is resolved with Version 5.00 ICU main Firmware.
    One of the revision updates on the firmware release notes:
    'L8-20 trouble may occur when condition signalling between internal modules is not performed properly'.
    Same issue is fixed with latest version 3.00 firmware on Virgo II series.
    Update the firmware. =^..^=
    • sharphead
      • Aug 2009
      • 285
      Re: mx3640 l8-20
      I had updated the firmware before original post the code didn't come back but the copier still managed to stop printing again disabled a few ports and it seems too be stable.
      had a 5140 stop printing the day the touch pad slow to respond not pinging etc. same port disablement seems to have sorted it.
