MX2610 pulling color DV
  • mttech
    • Mar 2014
    • 127
    I have an MX2610 that has pulled color developer out of DV units 3 times in last year and a half. Twice it was yellow and once it was cyan. I have updated firmware, replaced all ATC sensors, yellow DV unit, MC/DV PWB, PCU PWB, LSU, and all MC units. I also installed an uninterrupted power supply. Don't see any nicks or wear marks on the drums. I have had this happen in a couple other machines in this same series, but not repeating like this. Just looking for some guidance as my head is spinning.
    • 23006
    Re: MX2610 pulling color DV
    I know you say the drums look good ... but drum, blade and primary charge usually stop the developer dumping. I'd change drums and blades. =^..^=
    • iliketui
      • May 2014
      • 48
      One time during a training session on our showroom MX3100 with our Sharp Technical Expert the machine starting pulling the black dev all of a sudden.
      Don't know why it happened but the dev Bias changed itself to 0V. We changed it back to match something similar to the colour bias's and it has been ok since.
      • coopers1305
        • Nov 2014
        • 49
        To correct this problem I replace the process unit of the color that developer comes missing from.
