Print wireless w/USB print server -MX-C402SC
  • Toner Boy
    • Aug 2007
    • 365
    Before I attempt this (machine is also hooked up via ethernet), anyone have experience making this work? Recommendations, etc.
    In a hotel, staff can print via ethernet and scan, but guests and other staff would like to print via wireless (different network) to the machine. I'm hoping we can use SharpDesk Mobile to accomplish for use with Google tablets, phones, etc.
    Maybe will not work w/out ethernet?
  • JR2ALTA
    • Feb 2010
    • 2033
    Re: Print wireless w/USB print server -MX-C402SC
    It should work if you connect the wireless print server to the hotel's wifi. I am assuming that's what the guests tablets and phones would be connected to.
    It's odd though, hotels usually have desktops and printers available in those instances someone needs to print out an email or maps
    • Tonerbomb
      AutoMajical Resolutionist
      • Feb 2005
      • 2589
      I use a netgear wnce3001 wireless adapter to connect printers and MFP's to wireless networks. Much cheaper than the OEM's, and they work great. As for the Hotels, they usually have multiple networks that are separated by firewalls. One or two for customer/guest and an in house network that is for staff only. Access between both is usually not permitted.
      Mystic Crystal Revelations
      • mbcruzin
        • Aug 2013
        • 142
        In my experience the network scanner tool in Sharpdesk won't look across networks. Plus I haven't had great success with sharpdesk mobile doing the same. You might be better off setting scan to email and having the guests manual input their address. Then set up some sort of print server so the guests can get charged for the jobs.
