Sharp AL 1655
  • chris
    • Jul 2008
    • 10
    Sharp AL 1655
    This little toy machine has system error L1-00 in the display. I don't have a manual on this so wondering if anyone knows what this means, thanks.
  • ZOOTECH
    Senior member of CRS
    • 3375
    Your scanner lock is holding the lamp assembly from moving. It's located on the underneath side of the optic area where the paper feeds out. It's a round clear plastic knob that rotates to lock and unlock the scanner. Power off/on to clear the code after unlocking the scanner.
    • chris
      • Jul 2008
      • 10
      Cool, thanks man i feel like a dummy now
        • 23009
        I think everybody's got to do this at least once. The lock is in just the right place that you can fiddle with it with the fingertips of your left hand as you stand there at the copier. I must have phone fixed this at least 50 times. =^..^=
        • Vlad
          • Mar 2008
          • 23
          Scanner lock on AL series machines
          Thank G-d, the new AL-2030/2040/2050 don't have that lock installed.
