Virgo heads up
  • ZOOTECH
    Senior member of CRS
    • 3375
    Virgo heads up
    I have a few Virgos we got cheap because of broken displays/touch screen from lease returns.
    The slide out keyboard was dead (no LEDS) on one machine after display was replaced.
    I tried everything short of the PCU board, and the firmware updated to the 8.2 version.
    It was cloned from an identical working machine, so I thought all my settings would be good.
    I started hunting for items to check, or change, and somehow came across this setting
    under System Settings – Operation Settings “Key Touch Sound at Initial Point”.
    I put a check mark in the box, and the keyboard started working (verified by un-checking
    and the keyboard was inop). What is that function, and why would the kbd work on a
    machine with no check mark there? There must be something else causing this symptom.
    Have you heard of this, if so, please enlighten me?
    I am going to leave it as is with the check mark, and give machine a full going over operation wise.
    Have a great weekend.
    Spoke too soon, keyboard is not working whether checked or not, back to square one - bummer, ruined the weekend. (:
  • divad2k1
    • Sep 2010
    • 147
    Re: Virgo heads up
    Was the USB conv pwb replaced ?
    • ZOOTECH
      • 3375
      Re: Virgo heads up
      Tried a known working keyboard without a change.
        • 23002
        Re: Virgo heads up
        I did a little searching, and there's a member here that has some considerable experience on this inoperative keyboard issue:
        http://www.copytechnet.com/forums/sh...esponding.html
        Maybe he can help you. =^..^=
        • faxman28
          • 435
          Re: Virgo heads up
          if you have replaced the USB conv pub and keyboard, then replace mother-hub pub. have had this pwb fail, has the USB hub on it for keyboard and USB ports, check electrical section in service manual.
          • faxman28
            • 435
            Re: Virgo heads up
            the dreaded holiday weekend syndrome
            • ZOOTECH
              • 3375
              Re: Virgo heads up
              That was the first board I tried from a working machine, and then the MFP. Neither helped, until I put a check in the box mentioned in the op. It worked until I went to show a tech, and then I shot myself in the foot. I regret posting too soon, but I want to thank you all for your help. I'm beginning a new start for the long weekend (working on the cold ones), and will try again on Tuesday.
              Cheers everyone!!!
              • ZOOTECH
                • 3375
                Re: Virgo heads up
                Cheers everyone!!!
                Sorry for not posting the repair earlier; the problem was the cable to the USB converter pwb had a broken 5 volt wire that was intermittent.
                This is the 'scissor' cable (p/n DHAI-4704FCPZ) that flexes when the keyboard is slid out.
                • MdangerP
                  • Sep 2014
                  • 45
                  Re: Virgo heads up
                  Crazy. Nice find.
