Error Code E7-20
  • sharpsetup
    • Jun 2014
    • 10
    Error Code E7-20
    Working on a MX-M950 and I get error code E7-20 look in service man. talks about LSU. Did firmware update and did get to run about 100 copies before it coded out. Need a little help on this one.
    • 23010
    Re: Error Code E7-20
    Do you think it might have something to do with the laser? =^..^=
    • sharpsetup
      • Jun 2014
      • 10
      Yes I'm trying to fix it going to see about pulling laser out of another copier we have in shop.
      • Alpanapa
        • 20
        It may have something to do with the power supply.
        With smaller mfp, like 1810-3610, the E7-20, E7-21 etc problem is because the AC DC PWB dont produce 5 volt to the LSU Mother PWB (CN-104, pin 1 should measure 5 volt from Pin 1 to ground) if its less then 5 volt, you will get the E7-20, E7-21 error just as you described it. To fix that problem you have to replace the ACDC PWB.
        But in MX-M950 mfp you dont have an LSU Mother PWB, the power goes direct from PCU PBW to LCU PWB, so i guess it's PCU PWB or the regulator on the PCU PWB (That changes 24v to 5v before going to LSU PWB) or the HL PWB thats give the LSU PWB throughout the PCU PBW.
        • sharpsetup
          • Jun 2014
          • 10
          Thanks I will try and see what happens.
          • ZOOTECH
            Senior member of CRS
            • 3378
            Try reseating the connectors on the LSU; corrosion builds up, and by reseating connectors it has cleared up codes and quality issues.
