Sharp ARM276
  • reyasuk
    • Sep 2025
    Sharp ARM276
    We are trying to bring this photocopier back online but nobody can remember the key operator code. We have tried 00000 but it must have been changed, so is there a way to reset it? Many thanks.
  • DSallee
    Sharp, Ricoh, Lanier Tech
    • 27
    hi,
    You can go into service mode to display the key operator code.
    To do this:
    Press #
    Press *
    Press C (Clear)
    Press *
    At this point you should see a black box...
    type in 22
    hit Start key
    type in 7
    hit start key
    You should now see the Key Operator Code.... WRITE IT DOWN!
    To exit, just hit CA (clear all) a few times...
    This should get you going...
    Dave
    GFI Digital Inc, KC
    SHARP, RICOH, LANIER Tech
    • reyasuk
      Originally posted by DSallee
      hi,
      To do this:
      Press #
      Press *
      Press C (Clear)
      Press *
      type in 22
      hit Start key
      type in 7
      hit start key
      Dave
      Thanks very much for that, I'll try it first thing in the morning. You are a life saver!
      Jen
      • DSallee
        • 27
        Jen
        Glad I could help
        If you are not a service tech, please be aware NOT to go anywhere else in service mode because you could mess things up a bit if your not careful. Just follow the steps, get the code then clear out of service mode.. you should be fine..
        Dave
        GFI Digital Inc, KC
