Toner chunks in Dv.
  • vos.3305502137
    • Feb 2015
    • 7
    Toner chunks in Dv.
    I have an MX5110N that keeps getting toner chunks stuck between H-CUT blade and mag roller. Dv has been changed and only has 11k on it. Dv has been changed early by several techs. I have increase spacing and lowered preheat time and checked filters.
  • TreadHead55
    • Apr 2015
    • 6
    Re: Toner chunks in Dv.
    Check doctor blade gap according to the manual. Or get a new dev. assy.
      • 23010
      Good start! I would put a temperature probe inside the machine, with all the covers on/doors closed to see how hot it's getting inside. I would also check to see that each fan is running, and is installed blowing air in the correct direction. I had a Bear once that kept blowing thermostats. After much fiddling I discovered the fixing fan blowing in, not out. =^..^=
      • ntbann
        • Jan 2012
        • 632
        Empty DV unit, vacuum out then run feeler gage down entire length of doctor blade, and vacuum again. Have had to do this on a lot of sharp color machines lately.
        • spanky
          • Sep 2012
          • 468
          Be sure you have the updated lids on the developer units.
          They have toner filters that go almost the length of the dev unit.
          • FA51
            • Sep 2014
            • 15
            Obvious one but not been asked yet - is it genuine toner or compatable?
            Going back a number of years now but Raven toner (I think UK retailer was Parsia) had MASSIVE issues with the toners - could be something as simple as use genuine toner or another compatable brand?
            • travi
              • Jan 2008
              • 129
              We had a batch of toner with a production date of July 22 2014 tha cause this problem. We had 3 machines doe this all at once and it was right after the customer installed this batch of toner. We vacumed out the DV unit. Installed new DV and toner with a different production date. Problem did not reappear.
